JohnRowehl
- Location
- South Central PA
I have decided to take the plunge and repaint my Farmall 826.
I m planning on taking all the sheet metal over to a local body shop to spray paint. I will paint all the cast iron and heavy steel with a brush. A couple of questions:
What do you guys do for areas that are just too hard to completely take every piece apart and clean, sand and paint individually? The best you can?
What do you use to "sand" each paint layer before applying the next one in all these uneven places with all kinds of nooks and crannies? Steel wool?
Does it make sense to try to use hardener on these areas where it will be brushed? Would you need a supplied air respirator like you would for spraying?
