Al L. in Wisc.
I removed gas tank from Farmall 340 and have acid removing rust in tank; what can I use to plug the two top holes and when inverted, the bottom hole, to hold the acid in the tank? currently I have the tank in a small storage barn as it is raining and directions state don't add water to acid, also for ventilation.
I used a flashlight to peek at the progress last evening with tank on side and results are amazing. Any other tips and tricks for this process is appreciated.
