Hello,
First the hood: I bought a true 8N hood and started the cleaning/patching process. I have the YT primer and finish that I used on the rear wheels and about
to use on the fenders and front wheels. I'm wondering if I should paint the underside of the hood with the same finish color as the outside or use something
else so as to preserve or may conserve the good color paint. Should I be concerned with heat? What is recommended? I had not done any clear coating but is
that recommended?
Gas tank: I found an over 10 year old thread on the subject but maybe there are new paints or something now. Realistically, it will probably be the spring,
but I may start dismantling items yet this Fall.
a. regarding cleaning: one used a product called Prep-all, Is my degreaser solution essentially the same? The tank picture he showed was really nice looking
- silvery and shiny - I think he put a clear coat on too.
b. regarding tank painting. should I or not - or will that depend upon its condition? I've read that some came factory painted and some not. I've read
about some using gas resistant paint. I have Eastwood silver cad that I used on the rear rims that I thought I would use here, but I don't think it is gas
resistant. And what about heat resistant - reading of 8N owners saying their gas boils. What is best here to use?
c. I read about the gas cap having a vent - Is this obvious or is it just there in the way the cap is made?
d. I read that the tank itself has a pinhole vent at the dome area, but sometimes it gets plugged with dirt or even paint. Since my hood on the tractor when
I bought it is not the correct hood, maybe the tank was replaced too. Is this pinhole visible? I guess when cleaning I should be careful as I would not want
to get dust or anything inside - I think my inside is pretty clean. When I replaced all the fuel line, etc, all the filters were really clean.
Mounting tank to hood. Maybe I'll find out when I remove my tank from existing hood, but are there rubber strips or bumpers that are on the hood cross
supports or maybe on the tank that absorb shock - I believe I saw some restoration video a while back showing this. I did not see such in my parts manual - is
this a home-made option?
I appreciate all the advise. cfb
that recommended?
