water paint
Dune Country
Started painting back in the 70's,
lacquer, hand rubbed.
then enamel
Then arqurlic enamel
Then hardened above
Then urethane
now water based, any of you used it?
You see water paint all over, especially on GM vehicles. Easy to spot with it pealing off the primer. I'm not going that direction.
my shop switched to ppg envirobase water born several years ago. all the primers, sealers and clears are solvent based, the color coat is the water
borne. no problems.
