After a lot of GREAT input from the Ford board about the color gray I am going to paint my weights, (Don't know why I started the conversation there and not here) It looks like my best match for my 961 is the Gloss Light Ford Gray, 1964-1999. The Vansickle brand looks like what I need. Questions are, I already bought these quarts of Rustoleum Ford grey primer and paint I can't return. Can I use this primer or will it not cover being so dark? Is there any online places you recommend for getting the Vansickle? I assume I need the catalyst/hardener as well. Going to be doing all 24 pie weights, mounting plates and then a weight box and those 6 weights. Do you think 1 gallon should be enough with a couple coats? Going to be using a HVLP sprayer. Thanks!
