Time to do some paintwork
Credysis
It's springtime and I'm kinda looking forward to spring cleaning of some sort. But I was thinking of doing some paintwork too? What do you think? What are your projects lined up at this time?
Myself, about 10 years ago I painted the sheetmetal on a 1987 Kubota I have. The frame wasn't in too bad condition so I didn't do that. Recently I split the tractor so since I had to take much of the sheetmetal off I decided to paint the frame this time. After
cleaning it though I found out it needed a lot of seals. The fuel injectors were leaking, the rear engine seal, the PTO seal and I even put a hole in a freeze plug with the power washer. Amazing what dirt will do for you.
I did three major house jobs last year, this year I plan to paint a gable end of my old post and beam barn. the job will include a lot of new clapboards along with some jacking. I did a lot of jacking on it last fall. If that goes well I will do the front of the house. Before these jobs though I have a little more sanding and buffing of the clear-coat on my roadster project.
Sounds pretty good to me. I'm also planning on doing some exterior painting. But I haven't decided if I'm gonna change the color or just stick with the old one, maybe just polish it?
I found an article for porch colors. Thought someone might also be interested https://www.bobvila.com/slideshow/10-porch-colors-that-may-inspire-you-to-paint-yours-123775 Let me know you thoughts.
