HELP HOW TO TELL IF PAINT HAS THINNER IN
To those who know paint ?? I have a part quart of IHC red {2150} But cant remember if I had pre thinned with reducer or not. >>>WITH OUT
all the fancy gadgets how can I tell if I had mixed in reducer in the last year or not? IS there a simple method?
Thank you for all your assistance.
Wm.
I'm assuming you have enamel and that you'll be spraying it. It should be of a thin consistency if it's been thinned with reducer. When stirring with a stick, lift out the stick and watch the drips. It should not drip off like water, - somewhat slower, but not as thick as room temperature 20 weight motor oil. If you're brush painting it can be a little bit thicker.
So as I understand to test if I previously thinned, as I suspect, using a paint stir stick the paint should drip off just slightly like water that is near freezing or warmed honey in a jar. Let's hope that I did thin it last year so, I don't over thin it now, so I am able to put it through the LPHV gun.
Thank you for your assistance.
Wm.
thank you fellows
did find that your advice helped me
so I will need to by more IHC red to do the job but can use the half pint that I have > it dose have reducer in it using your method of testing.
Thanks again >Now have learned something new
Wm.
Paint usually goes bad faster if it's been thinned. I think if it's been sitting on the shelf a while I would dispose of it.
