Spray on bed liner
ldj
Will spray on bed liner cover spider cracks in fiberglass? If so will they re appear?
The bedliner would cover the cracks but they will probably come back and perhaps break first. If there isn't a lot of them I would grind the area down and put a patch of fiberglass cloth over the cracks and sand it smooth first.
I have a badly cracked Farmall steering wheel from 1950, and I went to O'Reilly's and got a can of black
spray-on bed liner, sprayed 8 or 10 coats, sanding in between, and it has been perfect. It/s held up
perfect, is grippy, black, has a texture, perfect. Cracks have not reappeared. Tough as nails.
