Fordson Model F re- PaintIng
560Dennis
Location
Madison,Ohio
I’m in the process of re-painting the old Fordson. I’m using Tallmans AG specialties color blend.
Most of the machine is cast iron castings. I wire brush ,sand , and degreased surfaces. I use a Rust-Oleum primer. After, that I ve used a base first coat with a cheap brush , application of tallmans paint. This paint looks like It has brush strokes in it as it goes on. But when I come back In 30 minutes to paint another section. The sections I did lookS great. I don’t know how this paint flows out and looks as if it was sprayed .
I thought about it , I’ve seen Fordson s come off the assembly line in Dearborn, and there is a worker going around the tractor with a brushes and paint bucket , painTing touch ups to the tractor and out the door it went.
I think maybe brushing the tractor is acceptable to me cause it looks good doing that way especially as well as the tallmans flows to a smooth surface.
I don’t know what they used to paint tractors in the early 1920,s but I did see a worker with a brush and paint bucket .
Any comments about early painting of tractors ?
Brushing paint is more technique than anything. Basically as soon as the paint comes out of the can it starts to set up. The more you brush the paint the more air gets into the paint causing it to set up prematurely which causes the brush marks. If a person applies the paint with a minimal amount of brush strokes it sits wet long enough to flow back together. Sometimes though the paint is designed to be fast drying or the weather is hot and it causes the paint to set up prematurely anyway. On those occasions you can often use a slower drying solvent or with oil based paints you can add some Flood Penetrol to the paint to slow the drying time down. This is more common with modern paints. They are designing them to dry faster and faster. In the old days, even as late as the 1970's oil based paints dried very slow. You could brush out the paint and it would still be sticky eight hours later. Personally I think the paint they made then were better. My dad used to paint ironwork without using any primer and it would last for decades.
(quoted from post at 05:35:57 06/09/20) Sorry , I m not finding what your telling me
It is here on "paint and body work and is titled OEM tractor paint.
Just click on Paint and bodywork.
