Stripping my 8n before paint using various methods. I don't like using a wire wheel as while it does remove the paint and rust it does seem to leave a smooth shiny almost polished finish. Using 80 grit flap wheel on all the red cast iron body parts and it seems to do a great job but it does leave some scratches. Some red parts are not cast like the tranny cover so I am not sure if the scratches from the 80 grit will show thru. I will be using an epoxy primer and then a single stage urethane enamel top coat. So will the 80 grit scratches show thru or should I go to a finer grit ?
All sheet metal will be done differently so I am not concerned about that right now.
Thanks
Alan
Thanks
Alan
