franknpdl
Will lowes spray primer work on small parts
like my float ride seat parts? I am using
acrylic enamel paint. Will the paint effect
the primer
Most spray can primers are lacquer based, dry quickly, sand well and are not harmed by most any top coat.
Some are not lacquer, but an enamel base and dry more slowly, and don't sand as well. These may be damaged by lacquer top coats but are fine with enamels.
So I guess the answer is, you should be fine.
