Company Logo Shop Now
TractorLinks.com
Clear Coat
Earl-IL
09-11-2019 17:49:38
Clear coat is pealing from sun. What can you do about it ??
showcrop
09-11-2019 19:19:35
 Re: Clear Coat in reply to Earl-IL, 09-11-2019 17:49:38
Once a few years ago when I stopped by the body shop down the road they had one that they were pulling it off from with razor blades.
Earl-IL
09-11-2019 19:28:14
 Re: Clear Coat in reply to showcrop, 09-11-2019 19:19:35
Thanks
Stephen Newell
09-11-2019 18:57:45
I know it's not what you want to hear but the only solution is to at least sand the clear coat off completely and start over. It's difficult to see when you start sanding so you might as well take it down to the primer. If you are putting a clear over a single stage paint you would have better luck is you would scuff sand the paint with 400 grit paper before applying the clear coat. The scratches created by the sanding will help the adhesion.
Earl-IL
09-11-2019 19:30:28
 Re: Clear Coat in reply to Stephen Newell, 09-11-2019 18:57:45
THANK YOU!
Copyright © 1997-2020 Yesterday's Tractor Co.
