What paint should I use on Massey Ferguson
steve4879
New User
I did some sanding for about a day and decided to have it sand blasted, please give me your thoughts on prime and paints, what is the best comb of prim and paint should use.
i will add pics as i go
Well, conventional wisdom is over anything sandblasted you want to use epoxy. To do that tractor with all the ins and outs you want to have your top coat already to go so that you cn apply it the following day. If you don't re-coat epoxy with in the given time you will need to scuff it all. You want also to use one brand for primer, top coat high build primer, base coat clear coat etc. I use Nason Axalta products for everything. It is mid priced, yet of automotive quality.
