The hardener will still makes it last much longer than it does out of the can. Another plus with the hardener is that you can sand, and buff out any runs, or dull spots. Without the hardener you can't, you will have to respray it.(quoted from post at 18:45:05 08/02/19) So they said that the implement paint was more durable and fade resistant. Also, you can paint over the equipment paint with the implement paint after 48 hours.
(quoted from post at 14:16:33 08/03/19) Acetone is too harsh. It might damage the resins that make it up. I went and got a can of the implement paint and the label instructions say to use mineral spirits. Spraying it though you could use naphtha. I wouldn't use anything stronger.
