treeman53
Thinking about repainting my JD B without taking it all apart. My question is this: is there a way to paint all the cast without stripping or sanding? Since I'm not dismantling, I don't want to blast it, and I don't want to strip it. I don't think sanding is feasible, because of all the crevices. Will epoxy primer bond to the old paint without sanding?
(quoted from post at 08:07:50 04/23/19) Thinking about repainting my JD B without taking it all apart. My question is this: is there a way to paint all the cast without stripping or sanding? Since I'm not dismantling, I don't want to blast it, and I don't want to strip it. I don't think sanding is feasible, because of all the crevices. Will epoxy primer bond to the old paint without sanding?
Spray oven cleaner to degrease it pressure wash it spray it again let it sit overnight then pressure wash again then use Sidegrinder and a knotted wire brush it will clean up easily.
