(quoted from post at 14:36:15 04/29/19) hello
can you wear glasses with a full face respirator? If not is there a certain spectacle kit someone recommends ? I have a opti-fit full face respirator if that helps?
(quoted from post at 08:58:39 04/30/19) I've got a 3/4 hp pump with 10 cfm max, and have 50' of intake hose for clean breathable air at all times with 100' of out let. I'm wondering if the outlet hose is too long? also on a day that it 60 degrees F, the air to the mask gets really hot. is that from the long outlet hose?
thanks
(quoted from post at 13:43:54 04/30/19) where is the pump?, you might just be recirculating your fumes
(quoted from post at 13:56:07 04/30/19) yakob, is your 100' hose full through? I got 2 50' hose sections hooked together with a quick coupler between them, someone told me one time that 2 50' sections together will cause restriction?
(quoted from post at 15:02:44 04/30/19) Pardon my ignorance here, but, why do you need a exhaust hose, mine does not have one just a one way valve.
