aluminum paint remove
DIM
What's the best way to get paint off aluminum with out damaging it. Do not want to repaint it but leave it bare
Use a methylene chloride type remover however don't use the one labeled "Aircraft" remover. It contains sodium hydroxide which is corrosive to aluminum. The biggest problem you might have is no remover works well below 70 degrees and if you take it inside to do it the fumes are a carcinogen and flammable.
