Bosch Injection pump fopr Detz-Fahr Dx-6.05
The tech who took my pump apart is gone. The estate sent me a box of parts and a list of parts to be replaced (he was preparing to rebuild it: couple of bearings and the usual gaskets, he had been keeping me in the loop). The problem is that no-one will accept my box of parts as a core! Also I'm not at ease with sending anything out hundreds/thousands of miles away having no idea about the moral integrity OR the quality-control available. I usually work with local experts that I know very well and who even invite me to look over their shoulder during the work done, often exchanging ideas about possible avenues. Any solid references, in or as close to Quebec as possible? These things are expensive and for a while there will be no local injection guru with an equipped test bench around here. Thanks.
I can't help you with names of injection shops in Quebec, but I suggest you check with local contractors that have their own shops, equipment dealers, truck shops, etc. to see where they send injection pumps. I think you will find most send them out, rather than maintain their own pump shop. I have to believe there is more than the one person doing injection work in Quebec. Admittedly not all may let you hang out over their shoulder.
You did not specify but are you asking about Quebec Province, which includes Montreal, or are limiting yourself to Quebec City?
You could ask this on the Tractor Talk Forum and it might get seen quicker by more Canadian members.
This post was edited by Jim.ME on 02/12/2023 at 04:52 pm.
(quoted from post at 15:36:39 02/15/23) I'm a Bosch technician at a fuel injection shop in Ky. Email me and maybe I can help you out.
I go to (your) profile>send-private-message but all I get is a blank page
It appears he does not have his email open in either Modern or Classic Views. If it was open in Modern, you would see a button for email next to his profile.
Your email isn't showing as open either so he can't email you. The private message function you see when you look at your profile does not work.
This post was edited by Jim.ME on 02/26/2023 at 03:30 pm.
