445 long piston and rod placement
RayinNc
New User
So I have a 445 long that came with a box of parts. The engine was disassembled. I have checked my manual and am having issue finding the direction the connecting rods sit on the crank. The cut is offset not straight across like automotive. Any help is appreciated
(quoted from post at 13:08:28 02/20/23) So I have a 445 long that came with a box of parts. The engine was disassembled. I have checked my manual and am having issue finding the direction the connecting rods sit on the crank. The cut is offset not straight across like automotive. Any help is appreciated
Conventional wisdom would be that the ''long'' side of the rod would be on the R.H. side, the ''loaded side'' during the power stroke.
Are there any marks or cylinder numbers on the rods, TYPICALLY those would face the camshaft side.
Well conventional wisdom wins again. That is how it goes. The manual I have is a copy of a terrible copy but apparently the stamped #s on the rod and cap face opposite of cam which makes your theory correct. Thank you
