Long 260 hydraulics
Cspringer1x
New User
Got a 1982 long 260 2cyl diesel. 3 point
lift isn't working drained the
transmission from plug underneath and
filter. It was mliky. Cleaned filter and
refilled with 17 q as instructed in book.
Do I run it and drain and fill a few
times? Or is there a way to flush the
system? It's a project for sure. Took
about a month to round down parts and
working diagrams to even get it started.
Long hydraulic oil will tend to be milky. A common problem on the lift is the check valve is stuck in it's bore. Use a 1 1/16 wrench, remove the hex plug under the seat. Remove large spring and hollow V valve. Clean and reinstall. then try the lift.
