Long 610DT 2nd Gear Pops out
JBoron
New User
Wondering if anyone has had a similar problem and what fixed it. I have a 1984 Long 610DT that was used HARD in a previous life. 2nd gear does not stay in, for High or Low Range. All other gears are fine. If i reach down and hold the lever it will remain in gear just fine. Any thoughts on what the actual cause may be?
Figured I would update. Transmission is opened up, and most internals are pretty worn with rounded teeth which is why it won't hold that gear. 2nd is the worst but the others aren't far off.
