Long 680 Hydraulic Cylinder Replacement Help
goebelmj
New User
My Long 680 has severe lift problems. I plan on replacing the cylinder/piston/seals.
Is there any advice and/or guidance to help me tackle this task?
Thanks all in advance,
MikeyG
Are you sure it's the cylinder and not the pump? I've got an Oliver 1365 which is a Fiat 640. The pump went bad on that over time
and it got where after lifting 15-20 round bales and moving them off the field, the 3pt wouldn't even lift with nothing on it.
(quoted from post at 11:42:28 03/31/22) Are you sure it's the cylinder and not the pump? I've got an Oliver 1365 which is a Fiat 640. The pump went bad on that over time
Pretty sure but not 100%. My front end loader is working fine so I suspect something in the 3 point assembly is causing the problem. I've pulled and cleaned the three indicated in the attached pic.
