leadfarmer
New User
A friend of mine bought a farm and it came with a Long 350 made by UTB. The tractor is functional but appears to of been neglected for some time. I offered to fix up the tractor in exchange for some other items so here I go!
1. First is filters and fluids. Not much to figure out there, except where is the hydraulic filter located? Is it a screen or replaceable cartridge?
2. The fuel shut off valve, below the left side of the dash, has the handle broken off so they use a pair of pliers to turn the fuel on and off (which is done regularly due to a leak I need to trace down). Any thoughts on where I can get the pieces for this shut off valve to restore the handle? Worst case, I can leave this valve open and add a shut off valve somewhere else in the fuel line to the lift pump.
3. The hydraulic steering pulls to the left constantly, nothing that can't be managed but it's annoying. I'm guessing that is internal leakage in the steering cylinder? Or is that an issue with the valve that diverts the flow? Any tips for rebuilding whichever is the culprit? I've worked on cylinders and such before, so no issue there, I just want to make sure I go after the right component and use the right parts.
4. One of the front bearing hub caps is missing. It has a nice duct tape job keeping in the grease. Open to suggestions on sourcing a replacement.
Other items like exhaust repair and cleaning up some cut off wiring won't be much trouble. Those items above are where I'm looking for info before I dig in.
