belarus 572
parkerhill
New User
have a 572 with loader front wheels will not turn .when i pick up with loader they turn ? shaft going to, turns but wheels do not. guessing have gear or spline stripped in front end .hoping someone else had this issue before I start taking things apart.
The support bearing assembly for the drive shaft is also a torque limiter, it is adjustable. Should be able to check by noticing if front part of drive shaft turns when front wheels should be pulling. Adjustment details should be in owners manual.
Thank you, the front shaft turns and the front wheels do not, pick them up and they turn with no pressure on them
