I have a 5040 Allis Chalmers but it has the same 3 cylinder diesel engine as a 445 Long so i thought someone on here might be more familiar with that engine, the parts book says the engine has a code that starts with 8035.01.305 or 306 but where is it out? I've found the engine serial number 62765 but nothing else.
Also i'm thinking this tractor might need a head gasket, its got quite a bit of blow by coming out the tube and the exhaust smoke smells like raw fuel, i know the compression is down cause its not easy to start. On one side of the block you can see that liquid has run down the block below the head at some point. I had a Ford 555 backhoe with the same symptoms and the head gasket had broke in two between cylinders. Think i should check the head gasket??
