Jacobsen G10 F10
Kirk-NJ
Have a hydraulic pump off a G10 or F10, I don’t remember which. Anyway looking for info on GPM or PSI. I’m looking to use this pump to run an external oil pump for engine in a ford RC puller. I can’t really be over 80 PSI. Here are the only numbers found on pump. 43YB001713-L>1A77Z
On an F10 my guess is the GPM and PSI are fairly low since it only used the hydraulics to raise the reel gang mowers, if the pump was off a HF series machine it would be much higher since it used hydraulics to power the rotary mowers. I don't know the technical data on the pumps. I have used and repaired both types of machines years ago when I worked at a golf course.
Any chance you can remember who made the pump at that time. Parker, Eaton, Vickers or other? Other than the numbers there are no maker marks on the pump.
