Readytoretire
Looking for some help, I bought a old stump grinder that has a wisconsin v465d engine. I have replaced the fuel pump, the starter switch and put in a carburetor kit in it before I even started it up. It cranked right up after it got fuel to the carburetor. It will run, grind anywhere from 5 to 10 minutes and then shut off. I can crank it right back up and it might run for another 5 to 10 minutes and shut off, again it will crank right back up. My question is there a temp switch on this engine that may be shutting it down. Where is it and what wires is it hooked to. I can buy a temp gun from Harbor Freight to check to see how hot the engine is getting, but I do not know what that critical temp a kill switch would be set at.. I took off all the gaurds around the engine and blew everything clean because it is a air colled engine before I even tried to start it. The key switch has about 7 wires going to it. If there is a kill temp switch, is it wired to the engine coil as a ground kill. Any info could help as to what is making this happen,. Thanks TC :idea:
