I've got a Long 2610, 4 cyl diesel, and it normally runs fine but in the last year after sitting for 2-3 weeks I've had problems getting it started and had to bleed it. The last time was this morning, I started at the injector pump and there was no air in the pump but when I cracked open the injectors I saw some bubbles. Once I got that bled out it ran fine, I used it about 5 hours with no problems. This is the 2nd time in the last year it's done it. Sometimes it can sit for a couple of weeks and be fine. I don't know if it's worse when it's cold but I'm in NE TX so it's not THAT cold.
Do you guys have any idea why I'm getting air in the injector lines when it's sitting? This morning it fired for about 5 seconds then wouldn't run again until I bled the injectors. Luckily I'm getting pretty good at it but it gets old when I'm in a hurry to do something and have to bleed it first.
Thanks,
Kerry
Thanks,
Kerry
