I have a 1996 Long 2610DTC FWA tractor with a FEL and all was good up until the end of last week. While pulling the disc the tractor started popping out of high range and I had to finish the field in low. Later I pulled the transmission cover off fully expecting to find some broken springs or lost detent balls causing the issue. Surprise, surprise, there is no such animal in the Long's transmission, at least not that I could locate. Does anyone have any experience with this kind of issue and what to do about it? Seems the only option right now is a bungee cord to hold the shifter into the high position.
