Belarus 572
Dieseltech
Location
Akron, Indiana
Anyone ever have the shift cover and lever off the 572 transmission? I have a late model that has lots of play between lo and hi ranges I'd like to tighten up some if possible. This is the single shift lever without the tee handle the earlier tractors used. Maybe some loose set screws, or worn half moon keys? Thanks in advance.
Other than high and low range, does gear shifting seem normal. Had a new 562M back in the day, and it had quite a bit of lost motion once put into chosen range. Also maintained another one, and don't remember it being any different. There are some videos on youtube of Belarus transmission repair.
