sonnythomas
- Location
- Brant, Ill
I don't see a regular gasket, just a sheet of gasket material.
(quoted from post at 09:00:30 08/04/23) There are 9 rings one for each port. Same gaskets fit an old 88. Send me an e-mail
(quoted from post at 09:28:21 08/04/23)
Switch to classic view and use the email link. He didn't enable it in modern view.
(quoted from post at 09:36:34 08/04/23)
Those little gaskets are part #KA422 (x9) as John said. They're available from the usual Oliver parts providers. If I was doing the job I'd probably get the manifold milled flat as well. Good luck.
(quoted from post at 07:31:20 08/06/23) That is not a bad job. Do it right the first time. More details later today! !
(quoted from post at 13:26:43 08/06/23) Milling can remove a mm or more at each pass, if necessary. A surface grinder generally takes off far less each pass (mine, which is relatively small - 18" x 6" with manual traverse - is best at less than 0.02mm per pass).
This post was edited by oliver90owner on 08/06/2023 at 01:28 pm.
(quoted from post at 16:11:11 08/06/23)
You don't need to fill out a dealer form. A member above told you Korves carries them. A google search shows Maibach carries them. Jerry @ Agpartsfirst carries them on his site. Rick's Ag Parts probably carries them as well. All are very reputable Oliver/White parts suppliers and supporters.
(quoted from post at 21:44:57 08/06/23) NEWIoliver posted about Korves. They carry many items not on their website.
The link to Maibach is here: https://www.maibachtractor.com/product/ka422-gasket-manifold-2/
Here's Agpartsfirst entire kit: https://agpartsfirstllc.mybigcommerce.com/gasket-set-manifold/
They are all very highly rated and we all like that.
This post was edited by scootergmc on 08/06/2023 at 09:46 pm.
