Thought I'd post a caution for anyone replacing their clutch throwout bearing/sleeve and the tube it slides on...
The sleeve should be ID 1.687. The tube number 1K585 OD should be 1.675. I received a tube at 1.691 so that did not fit.
New tube coming so will update with the results.
Meanwhile, I did add .008 shim stock to the clutch release shaft pivot points, so this thing should be really good when it goes back together.
