What Did You Do With Your Green Tractor Today?
JohnRowehl
09-18-2023 16:59:43
Borrowed this conversation starter idea from another discussion forum. (Not JD)
Saturday I drove it in my first tractor trot.
Today I had it hooked up to the 4240 plow to make some setup adjustments.
LandonT
09-20-2023 11:15:24
 Re: What Did You Do With Your Green Tractor Today? in reply to JohnRowehl, 09-18-2023 16:59:43
Had the gas tank off the 880 and am cleaning up the paint/surface rust. I see it has scrawled on the bottom 'S88 dsl' so that's interesting. Yes, it has the cleanout on the bottom and a copper line (breather?) on the back near the top. That's never been hooked up.
super99
09-20-2023 19:10:49
 Re: What Did You Do With Your Green Tractor Today? in reply to LandonT, 09-20-2023 11:15:24
The line at the top of the tank is for diesel fuel return from injection pump. If your tractor is gas, plug the hole with a pipe fitting. It doesn't need a breather, the gas cap should be vented
LandonT
09-20-2023 19:24:39
 Re: What Did You Do With Your Green Tractor Today? in reply to super99, 09-20-2023 19:10:49
Thank you, Thank you.
dnd
09-20-2023 08:19:47
Third Party Image
J.Wondergem
09-20-2023 06:01:59
I looked at them. Shined one.
super99
09-19-2023 19:17:46
Changed the 1850 from one way cylinder back to 2 way. Started changing the condenser on the 1550 and ended up puling the distributor and cleaning and lubeing it, new points and condenser and going for a test drive.
jhwis
09-19-2023 06:01:55
Fed a round bale with the 1750.
Steve Metcalfe
09-19-2023 05:53:28
Moved some hay with the 77.
Third Party Image
rrlund
09-19-2023 04:56:07
Fed cattle with the 1365, 1600 and 77, raked hay with the 1550.
Mike(NEOhio)
09-19-2023 04:41:20
Mowed some second cutting with the 1550.
GermantownGreen
09-19-2023 04:39:36
880 D on the big auger for corn
660 G was on the Kewanee elevator to the transfer truck moving corn out of the dryer bin.
I was running the sweep and didn't get a picture .
GG Wes
West Central Missouri
Have a safe day today!
GermantownGreen
09-19-2023 17:09:32
 Re: What Did You Do With Your Green Tractor Today? in reply to GermantownGreen, 09-19-2023 04:39:36
Here's the 880 when I had just got ready to raise the auger for the bin.
Just getting done tonight.
Last field of deer wrangled corn stalks.
GG Wes Third Party Image
dnd
09-18-2023 18:39:49
Third Party Image
scarl
09-18-2023 18:30:26
I drove my 1650 into local town Sunday morning and staged it for a tractor scavenger hunt
