JWinIndiana
As the title says, I have hydraulic fluid leaking at a very good rate from under the floorboard and runs down and along side the drain plug on the left side of the rear end near the bottom. No I haven't even opened one of my manuals on it. Seem to be chasing my tail as my mom had a stroke and a farming buddy is in the hospital getting a mechanical heart. The tractor needs to be split anyway as the hydro for the transmission was leaking and through advice here, shifted it into the other position and nearly eliminated that leak. This new leak will empty the hydraulic reservoir before leaving the driveway it is that bad. Is there a vent under there to check? Just wondering if anyone had a quick solution. Yes, I am going tonight to look at a replacement for this tractor but thought I would ask the brain trust here first.
