1850 PTO Lever
super99
I have the hydraulic unit off of my 1850, one of the bolts wouldnt stay tight on the lever that engages the pto . The top part of the threads is messed up. Ive been told that is a problem on these tractors . I think I should drill it out and tap it for a 7/16 bolt instead of the 3/8 that is there now. Anyone done this?? I have a 7/16 tap for a blind hole. Thanks,Chris
Just 2 3/8 bolts, not sure I have ever seen a brace for one. What is involved with the brace??
I put in a helicoil. I did some measuring, someone had put a short bolt in it and it only went in 3/8 inch so that's probably why it pulled out.
