Oliver 60 wide front?
So a friend gave me this 60 wide front. It is in bad shape to say the least. I was wanting to figure out what year it was made. On the block there is a brass tag. Says SN 615684. Just above the brass tag there
is a number stamed into the BLOCK. Reads 673327. I looked at tractordata and the number on the brass tag shows it to be a 1946. The number in the block would be a 1948. Don't see many wide fronts. What year is
this one? Thanks
It's a 1946 by the tag. I don't know what the number is stamped into the block but the serial number range for 1948 was 620257-625131.
Could the first 7 be a 1? Someone may have replaced the engine from a 1945 tractor and stamped the original serial number on the block, then swapped tags from the junk 1946 engine onto the 1945 in order to keep it original to the tractor. Just spitballin'.
