WHITE 2-70 BRAKES
yes.the pinion is not tapered on the shoulder where the seal rides, so take a pop can, cut the ends out, slit the side at an angle to make it longer, then use it as a ramp to make the sealing surface go up on the shaft instead of turning it backwards.
