Re: Super 55 Electronic ignition
John P.
Here is the link on this site I used when I did mine about 20 years ago.
The Pertronix is still going strong.
https://www.yesterdaystractors.com/articles/artint76.htm
Hi. Does your starter have a solenoid or
the mechanical rod? That solenoid would
need replaced for 12 volts. I would figure
out how many wires are needed and make a
new wiring harness. Also check for wear on
distributor shaft bearings as most don't
get oiled as they should. Personally I
would keep the points until I was
satisfied with the conversion, starting
and charging, then go to electronics.
