1750 Rear Axle Seal
pcrh
Hi:
The rear axle seals are leaking and it is time to tackle this. I looked up the parts on AgCo and they show 3 seals. Part numbers 103730A, 104235A, and 165123A in addition to 103871A which is an O-Ring. I found that the 103730A seal crosses to CR 32397 but have not found a cross for the other seals.
Is there a way to determine which seal I need before I take the seal apart? Also does anyone have a cross for the other part numbers?
Thanks
Dollars to donuts I *think* the row crop is going to be the CR/SKF 32397 seal as it was the same as in the 1850, 1855, etc. I'd just remove a side and see what's in there. I know Korves has the o rings and seals for a good deal.
Hi:
The plan is to work on the axle this weekend. I checked the axle size and it did seem to match scootergmc suggestion and that is what I have ordered.
Using B A Star crosses the dimensions do not match so thanks B A Star that helps confirm I have the correct parts.
