OC4/OC46 Distributor Cap
I know the 3 cylinder cap is NLA, but what is the part number on the comparable 6 cylinder version?
Also does anyone have a part number for the ujoints used on the later style driveshaft? OEM number on the ujoints was 609 195fs
Here is a post on this topic from Lou in WI back in 2010:
We get ours from Oreilly Auto Parts as follows:
Dist Cap OREILLY #BWD C16
NAPA # RR95
ROTOR BUTTON OREILLY # BWD D10
NAPA # RR83
POINTS
OREILLY # BWD A40V
NAPA # CS763P
CONDENSOR OREILLY # BWD6102A
NAPA # RR174
COIL
OREILLY #MPI E30
RESISTOR FOR COIL
OREILLY # MPI RU4
SPARK PLUG GAP IS .025
POINT GAP IS .022
RADIATOR CAP 3 1/2- 4 1/2 PSI CARQUEST # 33004
*** The new dist cap has ports for six cylinder,we plugged the extras with old plug wire rubber caps and JB weld.
(quoted from post at 15:34:18 08/08/23)
NAPA # RR95
NAPA # RR83
POINTS
OREILLY # BWD A40V
NAPA # CS763P
NAPA # RR174
COIL
OREILLY #MPI E30
RESISTOR FOR COIL
OREILLY # MPI RU4
POINT GAP IS .022
/quote]
Thank you for that. Any ideas on the ujoints?
