theking5983
just replaced my hydraulic pump with a pump for a 1650 I changed the correct drive gear for the new pump with all correct parts and added fittings to the power beyond to be able to attach a Backhoe, with the power beyond I attached a bypass hose so when the backhoe is not attached the hydraulic fluid can return to the res, without the backhoe attached at all and the bypass hose connected to the power beyond pressure side running to the return when I use the loader and dead end it the hydraulic make a grinding noise and when u dead end the bucket it makes the same noise but the loader wants to lift up a bit I am at wits end whit my Oliver 1550 1967
