A couple of days ago it started fine and I was mowing hay for a few hours. Yesterday I went to start it again, and it spit and sputtered a few times and fired a few times but then stopped. I tried again and again , and nothing. no firing . nothing.
I checked the carb and it was getting gas . When I checked the plugs , some were a little wet and others not. So I let it sit a few hours thinking it was flooded. Tried to start it again, and nothing. when I checked the carb air inlet, it was wet with fuel. so I thought it was a carb problem.
I took off the the carb (TSX 807) and cleaned all the jets with air and checked the float valve to see it was working and everything looked good. I installed it and tried starting the tractor again, and again nothing , no spitting or even trying to start, nothing.
I stared playing with the adjustment screws and now I can get it to fire but nothing that will keep it going. It spits and fires then dies.
I have come to the conclusion it is the carb that ios the problem. What is the correct adjustment of the screws on that carb?
Mine has two screw on top , one small screw and one larger screw.
Is the zenith carb a better carb and worth the money ?
. Any suggestion would be helpfull.
This post was edited by chas036 on 05/21/2023 at 10:30 am.
