Hydraulic valves
Can you adjust hydraulic valves on a White 2-110 so the lever stays engaged until the cylinder comes to the end of the stroke? I have to hold them all the time. More than annoying.
See the attached
It has been over 40 years since I worked for a dealer. Make sure the shafts where the handle mount on are free from rust an are lubricated. Make sure the compensator is set at the correct pressure!
