White 2-105 draft control
JP0503
Started plowing with the 105 the other day, but had a heck of a time getting it to go. Finally took a look at it and realized there seems to be no draft control. Was that an option back in the day, and if that is my case how hard is it to add that function?
Jp0503
I looked in the operators manual and both the cat 2 and 3 hitches had d/c, I was wondering if not having it was an option.
Jp0503
If it is a category 2 hitch (no external lift cylinders), could someone have repositioned the front lower link pins to the upper holes? That would render the draft control inoperative.
Here is a pic of the draft control settings from the service manual. I am having issue with my snip and sketch, so pic is all I can do.
It does not have a knob. I did some more looking in the book and found my answer. On the early models there was no in cab draft adjustment. However,there is an adjustment pin on the back end of the tractor. It has 3 settings: off, low and high. Mine was in low. I bumped it up to high and it worked like a charm. Thanks for your time folks!
Jp0503
