Im going to use an 880 I picked up recently on a John Deere 336 square baler. The baler is shared with the neighbor and has always been used on JD tractors with JD hygard
fluid. I will be draining and replacing the old hydraulic fluid in the 880 before I put it to work - Can I use JD hydraulic fluid in the 880 or would that cause an issue?
Hoping to find a way that we arent mixing different hydraulic fluids when using the baler
Thanks!
Thanks!
