super99
I got the unit off of the tractor and replaced the quad ring. The gear has 2 pin marks, one across from the other I tried close to a dozen times and cant get the gear all the way down, lacks about an inch from going all the way. I tried both marks, neither worked. I think the splines arent lining up properly. I talked to an Oliver mechanic and he said to take the snap ring and bolt out and then you can see that the splines line up . The snap ring is a bear to get out, I tried half a dozen times and just had to quit for the day and try again tomorrow afternoon. Anyone else have this much trouble putting the gear back in??
