Oliver super 55
FDBFarms
New User
Rebuilt pto clutch new clutch discs and metal plates can t get to to snap over handle moves with no resistance have looked in manual and watched videos can t see what not right
You have to turn that nut to tighten the clutch plates, but if you're turning it and it won't tighten up, the set
screw that holds that spider on the shaft might have slipped. That happened to mine. Best to put a short set screw
in the hole with another one in over it to hold it tight.
