Crankcase casting number?
So I have these numbers off of an Oliver engine that was in some sort of a backhoe. 155159A and below that was 190625. Wonder what CI that would be and what Oliver it would have been in? It has indirect injectors and a roosemaster pump. Also what size was in the 770 diesel?
Somebody on here had a 77 engine in an 88 or something didn't they? Was it Super99? The motor mounts should line up, but the block is an inch shorter behind the rear motor mount. I believe on the 88, the transmission is an inch longer isn't it? So that makes up the difference so the PTO shaft works? Or am I imagining that. I don't know if that transmission difference includes the 770 and 880 or not.
