Company Logo (800) 853-2651 Shop Now
1650 loader size comparison
rrman61
01-24-2023 08:13:38
In looking for a used loader for a 1650 Oliver what modern tractor size compares to a 1650 ?Can I adapt a loader from a comparative size tractor?I can make what I need to adapt one within reason
Mike(NEOhio)
01-27-2023 04:57:47
 Re: 1650 loader size comparison in reply to rrman61, 01-24-2023 08:13:38
rrman61, the 1550 used the same main case as the 1650 so probably the same width. I was a bit wider than the 4020 I took it off by about 5/8 inch at the rear mounting pads and 1 1/2 narrower at the front. I had to add 5/16 spacers to the spreader bar and 1 1/4 thick bars at the front. I can send you a print to drill the bars if you go that way.
rrlund
01-25-2023 08:13:27
As long as we're giving recommendations, I've got a Dunham model 22 on my 1600. Universal mounts and easy to adapt, but the loader is really too light, so I'd avoid it of you can find something else. It tends to twist awful easy. I don't like the way the bucket cylinder set up is on it either. It's a single cylinder that extends to roll the bucket back. That puts tremendous strain in the pin holes and causes them to wear out fast. I had to cut them out and put different one in it from a scrap loader that I have here. I modified it by going to two cylinders that pull back and a quick attach that matches the one on the White 1524 loader on my 1365. That fixed the pin problem, but not the twisting problem.
greg krush
01-25-2023 07:20:12
most any farmhand loader will mount up pretty easy, An F11 model will bolt right up to the rear axel and angle brace to the frame holes, other farmhand like the 228, 238, 258 will mount fairly easy. I have the 228 on a 1655, good visibility and interchangeable heads. I also have a great bend hi master 900 on another 1655, rugged loader but the visibility is poor. I run both loaders with PTO pumps for increased hydraulic capacity.
Mike(NEOhio)
01-24-2023 14:59:56
Just on FB and came across this one.
https://www.facebook.com/marketplace/item/3400178270240608/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking=%7B%22qid%22%3A%22-4826150362133321706%22%2C%22mf_story_key%22%3A%2236357594195837785%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A36357594195837785%2C%5C%22target_type%5C%22%3A6%2C%5C%22primary_position%5C%22%3A16%2C%5C%22ranking_signature%5C%22%3A3577260131781443584%2C%5C%22commerce_channel%5C%22%3A501%2C%5C%22value%5C%22%3A0.00022979832451912%2C%5C%22upsell_type%5C%22%3A129%2C%5C%22candidate_retrieval_source_map%5C%22%3A%7B%5C%225611189992311094%5C%22%3A3011%2C%5C%228608491905888984%5C%22%3A3011%2C%5C%225123518237775536%5C%22%3A3011%2C%5C%228681232901949569%5C%22%3A3514%2C%5C%225952186391487020%5C%22%3A3502%2C%5C%225875061362580520%5C%22%3A3502%7D%2C%5C%22grouping_info%5C%22%3Anull%7D%22%2C%22lightning_feed_qid%22%3A%22-4826157371431133974%22%2C%22lightning_feed_ranking_signature%22%3A%22165509983545327616%22%2C%22ftmd_400706%22%3A%22111112l%22%7D
Mike(NEOhio)
01-24-2023 14:30:34
I put a JD 148 on my 1550 without any mods except for two new holes for the front brace and a couple of bars to adapt the side plates. That series came with two or three frame versions. Mine is the row crop mount and it came off a 4020.
Third Party Image
Third Party Image
Third Party Image
Third Party Image
rrman61
01-24-2023 14:51:57
 Re: 1650 loader size comparison in reply to Mike(NEOhio), 01-24-2023 14:30:34
Is a 1550 shorter or narrower than a 1650?
Mike(NEOhio)
01-24-2023 14:47:41
P.S. I've seen a few on FB recently.
1970-1655
01-24-2023 10:41:43
I am just now putting the finishing touches on an Allied 594 on my 1650. The brackets that came with it were for some model of IH. The side brackets are full length, not like ones made for the Oliver. I added 6 to the rear and 2 to the length on the sides, using 1/2 plate. I drilled a few new holes, painted the side brackets, and it fits. I am still going to make a mount for a valve and plumb from power beyond to that. Then the hoses that came with the loader will work. After weather warms up this spring and I get a little use out of it, I want to take it back off and sandblast/paint it.
Third Party Image
Third Party Image
rrman61
01-24-2023 14:45:15
 Re: 1650 loader size comparison in reply to 1970-1655, 01-24-2023 10:41:43
Looks good to me.so an allied 594 or similar is doable;good starting point.do you know if some loaders will fit more than one brand machine or are all loaders brand specific?I use a loader every day on my CAT backhoe but dont know a whole lot about tractor loaders
young tractor
01-24-2023 17:35:38
 Re: 1650 loader size comparison in reply to rrman61, 01-24-2023 14:45:15
I have a white 1730 qa that came off an 1850 I might part with this spring. Its a pretty heavy loader though. What state are you in?
rrman61
01-25-2023 02:59:06
 Re: 1650 loader size comparison in reply to young tractor, 01-24-2023 17:35:38
Louisiana
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
Latest Ad: Looking for a Farmall super h steering housing the big cast piece in front [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
