Upper head gasket #161526A
68377
Oliver 1750 Gas, upper head gasket in between the head halves, not under head on the block.
Don't suppose anyone knows of one on a shelf somewhere possibly ?
Don't care to make one & can't find one anywhere I've called.
Thanks for any help
No not the valve cover gasket.
The head on this 1750 Oliver 283 Waukesha GAS motor is 2 piece. A lower piece of head & an upper piece of head.
Need the gasket that goes between the two parts of the head.
To the best of my sources the numbers below are:
Part # 161526A, old#105506A or I believe Reliance # S163674
Hello
Looks like maybe only one left out there. Call 330-939-4192 Maibach tractor, in Ohio
Hope they have it, Wayne
This is one of those parts that don't appear in the service manual, correct? What does Agco say about the part? NLA? I'd call Jerry at Ag Parts First.
Yes, Agco says NLA.
Will call Jerry @ Agparts First when holiday's done.
Thanks for all replies & most of all Happy Thanksgiving !!
Time to be thankful for family, friends & THE greatest country on earth !!!
Have you had an AGCO parts guy do a search to see if any other dealer has one in stock? A few keystrokes and they can do that. Just
because the warehouse doesn't have one doesn't mean that another dealer doesn't.
I have a 1750 gas head sitting on my bench that the prior owner says was rebuilt with seats and valves. Located in North central
Wisconsin. Not an answer to your question, but an option if you cannot find a gasket. Would sell at a reasonable price to someone
that would put it back to work. Steve.
(quoted from post at 18:50:06 11/24/22) I have a 1750 gas head sitting on my bench that the prior owner says was rebuilt with seats and valves. Located in North central
2SteveWI will keep that in mind. Thanks!!
Try Larry Svehlak at 512 633 5014. He has bunches nos Oliver parts &
lots of gaskets. He also farms & can be hard getting hold of, but
keep trying. HTH
